Is there a better plan than this?
C-Dawg
I’m currently in a £10 30 day plan where it gives me 2.0GB of data but it’s boosted with 16.0GB each month from accruing boosts over the years. See below pic:
However, I’ve seen there’s a 30 day plan available where you get 20.0GB data as standard. I’m thinking it’s a no-brainer to switch to this but want to double check I’m not missing something or there’s nothing hidden (like possible price rises etc)? Will I still get the opportunity to add boosts and will the data roll over if I don’t use it all?
Thanks 😊
Matt_124
As far as I can see you will lose benefits listed regarding the free-of-charge EU Usage.
You will gain 400 mins of UK Calls for a total of 500 mins of UK Calls.
You may want to read here in regards to Free Boosts and Rollover Data on the new plans: https://ee.co.uk/help/mobile/manage-use/pay-as-you-go/pay-as-you-go-mobile-plans-may2026
Future Free Boosts are capped at 12GB on the new plans.
You must be on a legacy PAYG pack having only 2 GB & 100 mins each period for £10. The current one you see online is better. It's having to buy a new PAYG SIM with a new no. You will earn Free Boosts with it & you will get Data Rollover of any residue from your pack. The downside for you is you won't be able to transfer your existing Free Boosts to this new no.
Matt_124
