I am abroad and my network is disconnected
nikoliyagenova
I am abroad and my network is disconnected as I have made any calls in the last few months. How can i re-activate, I topped up a credit but still is the same
Schockwave
Hello @nikoliyagenova ,
Welcome to the community,
Have just read in another thread, that there is a worldwide problem with roaming calls at present and that is why it is not working, nothing you have done wrong, but hopefully it will be resolved soon, EE are looking into it, but have no idea and I suspect no one in the forums will know what is going on.
@nikoliyagenova : Sounds like your PAYG SIM may have gone into hibernation due to non-use. If it has, topping-up now would be too late.
When did you previously make a chargeable action? EE PAYG SIMs are deactivated after 6 months of non-chargeable use. You then have a further 3 months period of grace to call EE to reactivate it before it is lost completely.
Ali_A
Hi @nikoliyagenova
Do you have signal showing on your device? Can you try switching your phone off and back on?
Ali
