on 02-09-2024 02:51 PM
I can not buy packs either using top ups or using credit cards and i dont not why.
Solved! Go to Solution.
on 02-09-2024 03:13 PM
@deanyin wrote:
i was abroad and not using the number for months.
Ah! Sounds like your PAYG SIM may have gone into hibernation due to non-use.
When did you previously make a chargeable action? EE PAYG SIMs are deactivated after 6 months of non-chargeable use. You then have a further 3 months period of grace to call EE to reactivate it before it is lost completely.
You needed to make a chargeable action like making a chargeable call or text, topping up or buying a Pack or Add-on, not just using your mins, texts or data from your pack.
on 02-09-2024 03:08 PM
@deanyin : Have you tried buying them from your PAYG by text? Text ALL PACKS to 150 & choose.
on 02-09-2024 03:10 PM
i can not text to 150 to buy any of the packs.Btw i was abroad and not using the number for months.
on 02-09-2024 05:15 PM
Hi, I mistouched the solved button, what's the procedure of making it chargeable? Now i have already have enough credit in the acccount.
on 02-09-2024 05:20 PM
Making what chargeable? If you haven't used it for ages & it's gone into hibernation you need to call CS as I said to get it out. In the meantime your credit cannot be used.
on 02-09-2024 05:48 PM
Okay, appreciate it. I'll try to make a call.
