Facing Issue
Abdullah0355
I recharged my sim but was unable to activate the package. Also I'm unable to make call
10 REPLIES 10
What does texting AL to 150 respond?
Not going
Where are you?
Pakistan
Northerner
Hi @Abdullah0355
Was the SIM activated in the UK, was it used in the UK.
When did you last make a chargeable call or text.
I just made 2 months back
Ali_A
Thanks for joining us on Community @Abdullah0355
Did you use your SIM in UK before going to Pakistan?
Do you have any signal showing on your phone at all?
You can check the costs for using SIM in Pakistan on our Roaming Page
Ali
Sir signals are showing but it's not working 😢
Christopher_G
Hi @Abdullah0355
If your SIM card was not used to make a call or send a text message whilst you were in the UK before going abroad, it will not be activated for international roaming until you return to the UK and do that.
