Data not rolled over
MW-M
Hi, I've just switched from a £10 plan with 8GB of data to a £5 plan (250MB) and as I had only used about 2.5GB I was expecting to recieve about 5.5GB of rollover data, but nothing has come through. I have had the data rollover on this swap on previous occasions so this is something new. Have the data rollover terms changed?
Ali_A
Hi @MW-M
Thanks for the screenshot.  I'd recommend giving Customer Service a call on 150 where a guide will be able to check your Rollover allowances and eligibility, and have this raised for investigation if you're missing data allowance.
Ali
10 REPLIES 10
There is no data rollover to or from £5 packs.
Not according to the website, for the £5 pack it says includes data rollover and this has been the case for the past 3 years that I've been using these packs. Has something changed that hasn't been conveyed to customers and the website?
Ritu_D
Hi @MW-M
Welcome to the community.
Are you on a 30 day £5 pack or 7 day?
Ritu
It's a 30 day £5 pack. Previous pack was a £10 30 day with rollover data
but i didn't get any.
Ritu_D
Have you recently changed to the £5 pack @MW-M ?
Yes, started yesterday.
Where on the website? URL please?
Ritu_D
Thanks for confirming that information @MW-M
You can find all eligible rollover packs here About Data Rollover
The £5 pack does not appear to be on the list of rollover packs.
