on 21-01-2023 02:15 AM
I would like to change my mobile number as I don’t want particular person having contact but incase and important person tries calling example hospital if i forget to update on system is there a way i could get alerted on new number and then call them back please help
Solved! Go to Solution.
on 21-01-2023 03:39 AM
Call CS & they'll change it for £36. The charge might be waived if you can show you are being harassed. However if e.g. hospital calls you on old no. you won't receive it.
on 09-02-2023 12:52 AM
I've just got my new ee sim and would like to keep my old number I have the pac code
on 09-02-2023 01:47 AM
@Zak1988 : Once you've used your SIM from EE, give your PAC from your current network to EE using Fill out this quick form to transfer your number .
