restriction code unlocking
Oliver56
Hi  I need to obtain unlock code as my old Nokia 6301 is locked to Orange and wont accept the new EE
SIM that I have been sent any ideas?
13 REPLIES 13
@Oliver56 : You can just apply for unlocking by using the Unlocking your device form and giving its IMEI no., which you can obtain be dialling *#06# into its keypad.
I have same issue for my mothers phone - as the Restricted code comes up as soon as switch the handset back on, it will not accept the *#06# at all to find the IMEI … any other tips?
@Maglyn  You enter the *#06# on the dial keypad.   All devices are programmed to understand that short code.
@Oliver56 if your device is locked orange, it might be worth considering purchasing a new device as 3G is going to be switched off. Orange never sold 4G devices.
Thanks Chris, strangely it just won’t accept it!  Like @Oliver56  it’s an Orange purchased 3510 (and yes working on getting her a 4G with keyboard as refuses to use smartphones but can’t currently until she is well enough to choose her own).
James_B
EE Community Manager
Hi @Maglyn,
What happens when you enter code into the dialler?
Have you tried pressing the call button after entering it?
Have same problem with Nokia 6303, orginally from Orange.
Unlocking Device form gives me a "client side exception error" when I enter the IMEI and press the "valiadate" button.
The 4 digit PIN that was on the letter with the SIM does not unlock it.
I tried entering the 8-digit PUK that came with the SIM and it does not help, the phone says "Code error".
I followed the instructions in the letter and received a one-time activation code for the SIM (6 digits) which does not work either.
Why does the letter not explain properly what to do with an ex-Orange phone? There must be thousands still in use. What do I do now? I have been to the local shop recently and they just told me to put the SIM in and it will work, which is patently not the case.
James_B
Hi @sharpener,
I'm sorry to hear you're having problems unlocking your phone online. With some older handsets, we may need to request an unlocking code from the manufacturer.
Please get in touch with Customer Care so a member of the team can help.
Magnifico001
Hi everyone
I have a nokia 6300 with is single sim based
I have issues with unlocking it from my own expereience.i need your help guys currently am in africa and i need to use the carrier services within.
The phone is powered by vodafone uk and still brandy
