annual mot
rossalex1978
Hi i was wondering if EE would repair my charging port as this seems to be broken and will not charge.
or will i need to take to a repair shop
Northerner
Hi @rossalex1978
You'll need to claim on your insurance for that issue.
@rossalex1978  with the device switched off have you tried cleaning out any fluff that can actually build up in the charging port. ?   Very carefully use a pin and see if you can remove any dust buildup from it.   Make sure the device is off.
 Also have you tried a different charger it could just be the cables/plug.
