System UI stopped working
LJM01
My LG phone I have had for 6 years has now come up with System UI stopped working I can not turn off to re-set
1 ACCEPTED SOLUTION
Leanne_T
Hi @LJM01
Thanks for coming here.
Which model LG do you have?
Can you access any of the menus?
10 REPLIES 10
Leanne_T
Hi @LJM01
I have a LG 2017 and my colleague had to remove the battery and re-insert to get the phone to do anything as would not switch off
Leanne_T
Thanks @LJM01
Is the message still showing after removing the battery?
The message no longer showing for now but not convinced it has worked as I have been having issues with the phone for a while the only reason it's not been changed as unable to buy a new phone
Leanne_T
I see @LJM01
Have you tried backing up your data and factory resetting the phone to see if this helps?
This would remove all data that you have stored.
If I did a factory re-set I would loose an app needed for my work and I d not have access to back any data up
Leanne_T
Hi @LJM01
Anything on the phone would be removed including apps, this would reset the phone to the factory settings.
You would need to create a back up of all your data and redownload apps.
Thank you for not helping
Leanne_T
Hi @LJM01
Trying the factory reset would help us to know if this would resolve the problem for you, once the phone was reset you can redownload any apps for work and transfer all your data back.
If this is not possible, if you give us a call on 150 the team will certainly see what options are available for you.
