EE PUBLIC WIFI STOPPED WORKING ON PS5
SQ9
For the past 9 months, I have been using EE public wifi on my PS5. You connect to EE Wifi but internet will fail. You open Network > Connection Status > View Service Status > opens EE public Wifi Authentication Portal > Enter login details > You now have internet.
The last 3 days - It will not allow me to access the authentication portal. I recently renewed my broadband contract for the next 24 months. It works on my phone as normal. I am considering cancelling it because of this. I am still within the cooling off period.
Peter_W
Thanks @SQ9, if possible it's worth trying this with a different EE hotspot to see if the same issue occurs, but I appreciate this may not be possible.
It's also possibly worth forgetting this on your PS5 and manually setting up the connection again.
We do also have a dedicated team for our hotspot network, and you can find more details on how to reach out to them here:
Contact us | Find WiFi hotspots | EE WiFi
Peter
14 REPLIES 14
Peter_W
Welcome to the Community, @SQ9
Just to be sure here, you've mentioned that you recently renewed your contract - is your PS5 still working on your home network?
Also is it just the one public access point that you've tried here, or have you tried several and seen the same issue?
Peter
Northerner
Hi @SQ9
Are you sure the pubic WiFi is genuine.
It may just be down as the service is designed for the public use and may just be inactive.
My broadband is set up in another home and works fine. I use EE public wifi in a separate home.
Im not sure what you mean by the second part. My main problem is - authentication page used to load allowing me log  in with my EE broadband account to access EE public wifi on my PS5. This was fine for the past 9 months but the last 2-3 days, the authentication page wont load.
Its the same wifi as its saved on my PS5
Peter_W
Peter
Tried everything possible. Will try hotspot team
Evv11011
Has to be a very recent problem as i have been having problems too . Was working fine last Tuesday and got back home today to try and login to public wifi and the authentication web inst loading on the ps5 just like that piccture . Pls fix this
Any help from the hotspot team??
Not really. They said ee wifi works off other neighbours routers who have "opted in" and it seems like a neighbour has recently opted out which is why authentication has failed.
That could have explained it...... but, it still works on my phone and laptop
I mentioned this to the guy and he said he wasn't sure.
