on 08-01-2024 07:44 PM
on 08-01-2024 07:56 PM
@Chrisrogers : Buy a suitable SD Card from an online retailer like Amazom (https://www.amazon.co.uk/s?k=sd+card&crid=16N6SJ3HYZLSR&sprefix=sd+card%2Caps%2C79&ref=nb_sb_noss_1) & stick it in the SD slot of your device.
08-01-2024 09:14 PM - edited 08-01-2024 09:15 PM
Another reliable retailer I've used over the years who have plenty of choice, is My Memory - https://www.mymemory.co.uk/
Check your phone's specifications as to what capacity card it accepts - SDHC generally go upto 32Gb, SDXC start at 64Gb.
on 21-01-2024 02:21 PM
on 21-01-2024 03:06 PM
@Chrisrogers : I don't believe so.
