on 04-11-2024 06:33 PM
I'm trying to upgrade my plan (phone + sim), using the EE Perk code that I get with my work, but every time I try to use it, it says that "Code entered is not applicable with this data plan. Please beware that certain codes aren't applicable if discounts are already applied."
There's no additional discount to the plan, so can't quite get why the code isn't working?
on 05-11-2024 08:59 AM
Hi @Cershaen,
Welcome to the Community!
We don't want you missing out on your Perk discount, so I'd love to get this checked out for you. Is the code you're using from our Perk Portal?
Rach
05-11-2024 10:29 AM - edited 05-11-2024 10:29 AM
Hi Rach,
Thanks for replying.
Yes, I'm using the code from the Perk Portal.
Thanks,
on 05-11-2024 10:32 AM
This does seem odd. Have you used this code before @Cershaen, or is this a new code?
Rach
on 05-11-2024 11:23 AM
No, I haven't. Just generated a new one and applied, but I didn't work.
Can I use this code on the phone or in the store?
on 05-11-2024 01:22 PM
on 21-12-2024 12:05 PM
Same with my. Tried to call but after half hour wait I gave up. I guess no upgrading this year 😞
