Re: How to switch my sim card into my name
Zoya2019
I order new sim
Good evening Leanne,
Thank you very much for your response; it is much appreciated.
I discovered a different method by going to the settings on my phone, then navigating to Mobile Service. From there, I was able to select the SIM and found an option to convert it to eSIM. The process was completed within a few seconds.
I hope this helps.
Kind Regards
Eben
James_B
EE Community Manager
Welcome to the EE Community, @Zoya2019 🙂
How can we help with your SIM order?
How to switch from my SIM card to eSIM?
Leanne_T
Hi @Ebenassann24
Welcome to the community.
If you currently have a physical SIM and want to change to an eSIM, you can do this by, logging into your EE account and ordering an eSIM. You can also pop  into an EE store with valid photo ID.
If neither of these options are suitable please call us on 150 and a replacement will be posted to you.
Hope this helps
Leanne 🙂
I hope this helps.
Kind Regards
Eben
Chris_S
Hi @Ebenassann24 Thanks for letting us know that you've managed to get it all sorted, and I really appreciate you sharing your advice 🙂
