01-10-2024 02:16 AM
Hi, I'm just in the process of porting back to EE as a new customer. I have a blue light card and the app shows a discount on monthly plans.
When clicked, it puts me through to the EE site to progress the order but the discount is not applied.
I've tried putting the code in to the promo box and that doesn't work either.
Any advice please?
01-10-2024 09:05 AM
Hi @SamFoord1
Welcome to the community.
It is great to hear that you are moving over to EE.
You are putting the discount in the right place, so there is no problem there.
Was the plan you were selecting already showing a discount or an offer?
Michael
01-10-2024 09:41 AM
No, the contract price remains the same, no discounts are applied.
It's the 25gb essentials SIM only for £16/mth.
Thanks,
Sam
01-10-2024 09:45 AM
Was it a 12 month or 24 month contract? @SamFoord1
Can I also check who it is you work for? We may be able to get you register for our EE Perk discount to see if we can get the discount that way.
Michael
01-10-2024 09:48 AM - edited 01-10-2024 09:49 AM
24 month
Blue Light, HM Forces Veteran
Thank you for your help.
01-10-2024 12:15 PM
Thanks @SamFoord1
If you add another plan to the basket, does the discount code work? Don't worry it won't stop the code from being used.
Michael
01-10-2024 02:03 PM
Unfortunately no it does not work.
01-10-2024 06:25 PM
Hi @SamFoord1
Was the code generated through the EE Perk portal, or through Blue Light Discount directly?
01-10-2024 07:04 PM
Hi, it was generated via the blue light app/site for the code. It also takes me direct when the link is clicked. Neither way produces the discount
02-10-2024 07:07 AM
Hi @Michael_D,
I believe this SIM is a TLO offer and hence not eligible for any discounts after Tariff Refresh. Discount is only available on Core Offer SIMs.
