I have a blue light card,
Lesliepeart
I have a blue light card, i have 9. Lines, bb n tv with ee, am I entitled to ant further discount
Michael_D
Hi @Lesliepeart
Some great advice from @Northerner above.
It is worth noting that often the Blue Light discount can only be used by new customers, not existing ones, although the terms of the offer on the Blue Light page will usually outline that.
If your employer is part of our Perk scheme, then you can get a discount on eligible mobile plans when upgrading or taking a new contract.
The discounts cannot be added to a contract that has already started.
Michael
Northerner
Hi @Lesliepeart
Have you checked: https://www.bluelightcard.co.uk/ee_nhs_discount.php?srsltid=AfmBOooA5KUUW0vcE4q9bv3s9Vh-qMvHHlGb5DXz...
Have you registered on the perks portal: https://perk.ee.co.uk/
Michael_D
Hi @Lesliepeart
Michael
