on 22-11-2025 12:49 PM
Any updates whether the timespan given by the website is correct and will it be delivered on time
Solved! Go to Solution.
on 23-11-2025 10:58 AM
Thanks @Brunomars23.
At the point you ordered, the iPhone 17 Pro Max 512GB in Cosmic Orange had a estimated dispatch timescale of 21 days.
Once stock is available for your order, you'll get a text or email from DPD, or a notification in the DPD app if you have that to let you know it is on the way and when to expect delivery.
Michael
on 22-11-2025 03:30 PM
Hi @Brunomars23
Welcome to the community.
The timescales given at the point of ordering are usually accurate, although there may be delays if stock has not arrived when expected.
If you let me know which colour you've ordered, I'll have a look at the stock guidance.
Michael
on 23-11-2025 10:42 AM
It was the cosmic orange 512 Ordered on November 16th
Michael
