USA Roaming Abroad Pass
Kristian86
Hi there,
currently in the states for a month and I have a travel pass add on as standard but I was wondering if the roaming abroad pass for £25 a month would be more worth while? I have unlimited data but i only seem to get so much allowance per day and then it gives me the option to pay £6 or so to get 500mb of data! I’m obviously using WiFi as much as possible but often away from WiFi during the day so wanted to see if there was a cheaper better option?
Any advice would be great, thanks!
@Kristian86 : Yes, the Roam Abroad Pass would be well worthwhile. It would allow you to use your UK data there up to 50GB pm rather than the 500MB/day that the TDP gives you, as well as covering making & receiving calls & texts.
