20-11-2024 09:23 AM
Did anyone else get a text saying “Hi from EE. We've removed your TNT Sports from discovery+ Inclusive Extra. You can manage your extras in the EE app. Thanks.” ?
I never requested for it to be removed and it comes as a surprise not even halfway into my contract. Is this a mistake on EE’s part? This is my first negative experience with EE.
27-11-2024 08:56 AM
That didn't work for me, still the same issue
27-11-2024 10:01 AM - edited 27-11-2024 10:05 AM
Hi @eeuser169 @dentos
If you're still seeing an error message, have you tried adding this using Chrome?
If the One Time PIN is giving you a spot of bother, have you tried to disable any WiFi connection and just use mobile data only?
If neither of these work then I would suggest speaking to our technical support team and they can get this sorted out for you both.
Linzi
27-11-2024 10:21 AM
Hello,
I've tried using chrome, brave, edge, and safari. All on mobile with wifi and mobile data, and also on a desktop. It's the same issue with all of these methods.
I spoke with technical support who advised that it's a known error on EE's side and they are working on a fix. In the meantime they've given me a temporary one month pass and hope to have the issue sorted by the time that runs out.
27-11-2024 10:24 AM
I have managed to reactivate mine using the Chrome browser on my mac. Wouldnt work using iPhone any browser.
27-11-2024 05:20 PM
Had similar issues past few days. Ee tech support was unable to help. Finally today, it worked on Windows/Chrome browser. Not sure if relevant but I had enabled two factor authentication just before I got it working so might be worth a try.
