06-08-2024 10:18 PM
Hi I have a Samsung galaxy watch 4 that I bought from Currys with cellular 4g built-in I'm just wanting to know if I go to EE can I add a mobile data/watch plan to the watch. Just need a 100% yes or no
07-08-2024 12:36 AM
Hello @Harry66
You can add a tariff to it via the wear app. You have to be a contract customer ( including sim only contract ) to add a watch tariff. The watch tariff will be £7 per month on a rolling 30 day contract and you’ll get 10Gb of data for the watch, it’ll share your call and text allowance from your contact.
07-08-2024 01:31 AM
Are you 100% sure you can do that EE have been saying yes then they say oh no you can't I'm just confused about the whole thing
07-08-2024 01:50 AM
Hello @Harry66
Yes this is 100% Correct
You will need a Paired Watch Plan.
However this will come with a separate number for billing purposes. Will share the Same number as your phone.
I have a Samsung Galaxy 4 Classic Smarthwatch 4G version aswell.
07-08-2024 02:24 AM
The reason I'm asking these questions because I bought a smart watch from Currys with WiFi only not cellular.
So I then when to the EE store about 2 weeks ago and they said they it can't be added on because the watch I brought was WiFi only not cellular so I have asked EE in store they then said the watch has to be on the same network as EE that's where the confusion is I think.
So I when home then phoned up EE they said yes you can buy a watch outright from Currys with cellular data then just go to a EE store and then add the watch plan on the it's self people are telling me one thing then a different thing the next. I appreciate your help sorry about this.
07-08-2024 02:42 AM
The watch must have 4G Cellular Capabilites in order for you to use a eSim plan on it.
07-08-2024 03:22 AM
Thank you for helping me understand that you can buy a watch outright and then add a watch plan on.
But why would EE themselves tell me you can't when you are saying that you 100% can do that are they trying to hide something from customers knowing about this type of stuff.
