on 28-06-2023 06:18 AM
Hi how much is it for my daughter to use her phone in South Africa ? Can I buy a 2 week roaming pass for her? She’ll need internet and texts. She will not be calling the uk
Solved! Go to Solution.
on 28-06-2023 07:49 AM
Hi @vlc126
Welcome to the community.
Please take a look at our roaming costs tool for South Africa. It's worth texting ROAMING to 150 before travelling too, just to make sure the SIM is set up for using it abroad.
Hi @vlc126
on 28-06-2023 02:14 PM
The Roam Abroad Pass is not valid in S. Africa.
on 22-12-2024 08:47 AM
As the roaming checking part of the iOS app is rubbish, is roaming in South Africa still not supported by EE ?
The link that you included doesn’t work !
on 22-12-2024 11:34 AM
Hi @Fourqtwo You'll be able to use your phone in South Africa if you were to travel there.
To see all of the charges involved, just click this link here, this should take you straight to the South Africa call charges and bundle options: South Africa
Chris S
22-12-2024 12:25 PM - edited 22-12-2024 12:26 PM
@Fourqtwo : If you are on contract, you may use your usual UK allowances outside the EU with up to 50 GB data per billing month if you have more, when you buy the Zone 1 Pass for £5 / day or £25 / week. Otherwise you will need to pay the charges or buy roaming add-ons as set out in https://ee.co.uk/help/mobile/roaming/roaming-costs/countries/southafrica.
If you are on contract, just remember to text ROAMING to 150 before you leave UK to ensure the roaming ability is enabled on your account.
If you are on PAYG, just make sure you had already used your PAYG SIM to make a call or text in the UK.
