on 26-04-2024 04:15 PM
is roam abroad pass charged by billing cycle or calendar? For example if the billing cycle starts 16th of the month are you charged from 16th or from the 1st of the month?
Solved! Go to Solution.
on 26-04-2024 05:10 PM
@PastorMark : By billing cycle.
The Roam Abroad Pass costs £25 per billing month from the billing month you order it (text ROAMING PASS to 150) until the billing month you cancel it (text STOP ROAMING PASS to 150). For all billing months during which you have the Pass it is charged at the full £25. However if the Pass is carried over from the 1st billing month to the next it will be charged pro-rata for that 1st month alone.
