Roam Further Pass for USA
Mikey52
I will be in the USA in a few weeks and have a question regarding the Roam Further Pass. If I purchase one for £9.50 +vat, then I can use my phone as if I was in UK. For data I am currently on 10GB per month, would this be the limit for use in USA for me.
Reading comments on here a few months ago, I recall that when you purchase a Roam Further Pass  for a month it includes data of 50GB, is this correct or was I dreaming, if not can you add more data should you need it while there. Thank you.
1 ACCEPTED SOLUTION
Yes, you would be limited to 10GB data per calendar month while roaming in US & EU.
The Roam Abroad doesn't include any data of itself. It merely gives you the right to use your UK data while abroad, up to a max of 50GB if you have more.
6 REPLIES 6
Mikey52
Hi, When you purchase a Roam Further Pass how much data does that include, is it your normal limit (mine is 10GB). I have read some comments on here that make me think it could be 50 GB, which is correct!! Thank you.
@Mikey52 : I'd already answered this in your previous thread (now this). Why are you asking again? Nowt's changed in the meantime.
Hi, When I posted earlier, I had no ‘notifications’ it had been read, I also thought I had selected the wrong section in the drop down box, so that’s why is did it again.
You don't get notifications when posts are read, only when they are responded to.
Hi XRaySpeX - if I have added on a data bundle to my plan, would the roam further include that extra data in the roaming allowance? e.g. I normally have 6 GB on my plan, but if I added say 10GB for a month, would that mean I had 16GB for use in USA?
Thanks in advance
