30-03-2023 10:45 AM
can I purchase any of the travel add-one for one month only? Or once you’ve signed up are you then contracted for a certain length of time and subject to lengthy cancellation process?
I’m going to US for a holiday, so just need a travel add- on for a short period.
Thank you
30-03-2023 05:27 PM
The Travel Data pass sits on your account as a free add-on, @Pog4. It only kicks in when you use your data abroad. This EE Roaming | Travel Data Pass help page explains it more.
The Roam Further Pass is a 30-day rolling add-on so once added it will stay on your account, with the cost added to your monthly mobile bill, until you remove it.
This means you have the flexibility to add the Roam Further Pass to your account for one month, remove it the following month and then re-add the month after.
How do I get the Roam Further Pass?
Hope this helps.
30-03-2023 02:53 PM
30-03-2023 04:23 PM
The roam abroad pass or perhaps the travel data pass
thank you
30-03-2023 05:27 PM
Hope this helps.
