Netflix add-on link not working
littledutchboy
Hi there,
Sorry, I made a mess of my post and then couldn't delete it. I have resolved the problem now (basically it seems I have to go via the desktop rather than using the mobile link to activate the reward).
Adrian
Lesley_W
Hi @littledutchboy
Welcome to our community.
Can you tell me a bit more about what happens when you try and use the link?
Lesley
Hi there,
Adrian
Lesley_W
Thanks for the update @littledutchboy
I'm pleased you're sorted and enjoy your Netflix!
Lesley
