Netflix Activation not working
cdeimerej
This is a long one!
April 17th I upgraded to EE from BT via a BT guide to a broadband and TV package including TBT Sport. During this upgrade I was told and have email confirmation dated 17 April that Netflix was part of my TV bundle to avoid having to pay for it directly myself (and would just pay the difference for a premium account) which I had been doing previously - so essentially I have an existing Netflix account!
I receive the activation email via EE on 17 April but when I try to use the link nothing happens when I am signed into Netflix and it spits out a "Something went wrong error" when I am not signed into Netflix.
I use chat support and they say that because my service with EE doesn't start until a week later 24 April that the link won't work, so why send it that early!?. So I wait until 24 April, EE TV box arrives, I set it up and go to Netflix app but nothing happens no option to move to EE or to add to EE billing, I just sign in and it takes me straight through.
Between then and now, 7 June 2025, I have used chat support twice and called customer services twice while being passed around like I was the ball for prime Barca in a never ending loop of trying to figure out why my Netflix Extra benefit is not working. Some guides say it isn't on my account while others who seem to have deeper access to my account can see that it is on there. Who knows at this point!
I have been asked to cancel my direct payment with Netflix and the EE Billing should take over when it ends - it didn't.
I have been resent the activation email twice, no luck still - same issues as before constant errors. Doesnt even matter what device I use (iPad or Phone)
I got so tired of going round in loops, I decided to just remove netflix but the offer I received and had to cancel was more than what I pay already for less services!
I have reset the TV Box, reset my passwords (as per advice from an EE guide) but still nothing.
So please EE or someone, help me. I just want to get it working and make full use of what I am paying for. I'd like support from one person who knows what they are doing and not just reading instructions off a script.
Even though the broadband and rest of the TV and customer service is usually good this issue seems to befuddle all of the guides I chat or speak to. No resolution leaves a bad impression despite all the good and I'm starting to believe that upgrading from BT was a bad idea.
Michael_D
Thanks @cdeimerej. Looking on the website, the Sport package does not include Netflix, which would be why it is not letting you add it.
The only packages that include Netflix are the Entertainment, Big Entertainment and Full Works packages.
I've looked at the email from when I signed up, like the one you've put above, and Netflix was listed in the 'What's included in EE TV' section, rather than the 'Your EE TV extras' like your one.
Michael
13 REPLIES 13
Katie_J
Good morning @cdeimerej
Thanks for coming here.
I understand how frustrating this must be and I will do all I can to help.
When you get the error does an error code show?
What Home Broadband and TV package do you have?
Katie
Hi Katie,
I am on Full Fibre 500. TV Package includes TNT Sports.
For some reason also, Netflix does not show under my addons or extras section.
Unfortunately no error code shows. But the web address is https://www.netflix.com/partner/paymentintegration/partnerError
Thank you
Michael_D
Thanks @cdeimerej
If you go to the EE app or login through the website and head to the TV & Sport section, does it show Netflix as being included in the package?
If it does, is it showing you can activate, or giving options for Manage and Recover your account?
Michael
Hi Michael,
As my reply to Katie, in the EE app or websites it does not show  up in my add-ons or extras.
I raised this at the start when I upgraded and used the chat support. They said it was a technical issue.
Like previously, I am being told it isn't on my account but some guides say it is.
Thank you
Michael_D
If it isn't showing there, it doesn't sound like it is active @cdeimerej
When I set up my EE TV package, I had the option to activate Netflix the EE account, which triggered the email with the link you mentioned above. That then recognised I was due to have Netflix and activated the subscription.
If you look in the TV & Sport section in the EE app or website, what is the exact TV plan it shows you have?
Can you also send me a screenshot of what it shows under 'What you've got' in that same section?
Michael
This is what it says under the what you've got. And to make sure I'm not going crazy - a screenshot of my order email to confirm I did have Netflix as an extra.
Michael_D
Michael
