on 16-12-2022 07:30 PM
Hi I have created an account with my nhs email for getting NHS perk 20% code but when I try and follow the link about claiming code it says my user name and password are invalid yet that is what i've used to log onto the account?? anyone else managed to get around this? I already have a personal ee account with my mobile linked to it so don't really want to add this to a work email and confuse accounts. Thanks
on 17-12-2022 10:07 AM
Hi @madmax66,
You'll need to login to the Perk portal with the work email address you registered with, rather than your My EE login details.
Hope this helps.
on 17-12-2022 03:33 PM
Hi James
Thanks for replying, i am using the NHS email but it says login details are invalid which i dont understand as i can log into my new nhs ee account with those same details? and when i tried creating again in case its not worked an account one already exists (obviously) under my nhs email, so not sure how i can the code now?
Maxine
on 17-12-2022 03:40 PM
Hi @madmax66,
Can you share the URLs of the login page that you can get in to successfully and the one that you can't?
on 17-12-2022 03:57 PM
https://perk.ee.co.uk/account/login
should i be registering the number i want the discount for? this will be my husbands number
on 17-12-2022 04:06 PM
Hi @madmax66,
The first link is for My EE, which is used to manage your EE account.
To generate a discount code, you need to use the Perk portal. Before you can generate a code, you'll need to verify your email address using the link sent to you via email.
When logging into the Perk Portal, you'll need to use your NHS email address and the password you entered when first registering for Perk. (This may not be the same as your My EE password.)
Hope this helps.
on 18-12-2022 05:31 AM
What do I do if I already have the codes? I can’t seem to see how to add to the re account,
on 18-12-2022 09:29 AM
Hi @Bgemm21,
You can add your discount code to the 'got a voucher' box when checking out online.
Hope this helps.
