EE perk code not working
CyrilS
Dear EE
I am trying to upgrade my SIM only plan to your 24 month £15/month plan. I have a new EE perk code which should give me a 20% discount but when entering the code in the “Got a promo code” section I get an invalid code error. Have tried 2 different codes, different browsers, desktop computer and phone and no joy. Could someone please advise next steps? Thank you in advance.
7 REPLIES 7
James_B
EE Community Manager
Hi @CyrilS,
Is the plan you chose already discounted?
Does not appear to be
Christopher_G
Hi @CyrilS
Do you have any existing discounts on that phone number?
Yes I do. This was applied >12 months ago as the EE 20% perk did not pull through and had to be done manually by the team after discussing things on 150. Surely this should not affect an upgrade with a new EE perk code.
Christopher_G
If they have used a non-perk discount, it's probably clashing with the actual Perk discount going on, @CyrilS
It may be worth giving us a call on 150 so that they can check your account and advise further.
Becat-
I am getting the same issue did you manage to sort it?
Ali_A
Thanks for joining the community @Becat-
It would be best to call Customer Care on 150 so the upgrade team can check what could be causing the issue and manually process the upgrade with code for you.
Ali
