Perks code
ebk
Looking for some help......
I have logged in and received perks code but whenever I try to use it it says it isn't valid. I have tried it against a number of phones and plans but it still says the same.
I called EE but they weren't able to help. Is there any way of trying to speak to somebody directly about this? I have already started the process of leaving my current provider so frustratingly I will need to look a another network if I can't get it sorted soon
Michael_D
Hi @ebk
Welcome to the community.
It would normally only give you an error if you were trying to use the code against a plan that wasn't eligible, or if it was incorrect.
Have you tried to manually type the code, rather than pasting it?
What phone and plan combinations were you looking at?
Michael
