Add line is not working with F&F discount code because of another 10% discount
Tartanterror2
We have a problem where we are trying to add a new line to an account with the F&F discount code through the app but every plan has 10% off which is stopping the F&F discount code from working.  Can someone help please?
9 REPLIES 9
You can't have > 1 discount on the same order.
@Tartanterror2   That’s because a 2nd line gets a discount automatically on the account..     you’ll have to call and speak with customer service so the 2nd line discount isn’t applied and you can add the F&F.
Tried that 4 times and they said they couldn’t help unfortunately
This isn’t the solution. Pressed that by mistake
James_B
EE Community Manager
Hi @Tartanterror2,
Are you able to remove the multi-line discount if you select edit in your basket?
What was the solution here? I can't see a way to remove auto applied multi-line discount from the baasket
Katie_B
Hello @SlawekP
Have you tried selecting edit in your basket?
Speak soon,
Katie
Yes I have. There is nothing in basket edit allowing to do this.
Katie_B
Thanks for checking @SlawekP
If it is not allowing you to remove this online I would recommend giving us a call and speaking with our sales team.
Katie
