02-10-2023 05:56 PM
My Samsung Galaxy A12 will not work with WiFi Calling - Should it?
02-10-2023 06:01 PM
Ho @akc2
Dial *#1234# and post the three sets of numbers.
02-10-2023 06:15 PM
Where are dial settings?
On monthly contract
WiFi is working
02-10-2023 06:20 PM
Has this phone worked for WiFi-calling in the past?
Can you explain how it's not working currently?
02-10-2023 06:28 PM
02-10-2023 06:38 PM
You posted to say your phone is not working with WiFi-calling - how so? How is it not working?
02-10-2023 07:02 PM
02-10-2023 09:28 PM
So your symptoms are that WiFi-calling is not kicking in when you think it should. Does your phone show a VoLTE indicator next to the signal bars, and if so are you able to make & receive calls?
WiFi-calling is normally set to only kick in when 4G-mobile coverage is deemed unusable, based on radio-criteria. Many Android phones have an option to toggle between "mobile preferred" & "WiFi-preferred" under the WiFi-calling settings. Does toggling yours to "WiFi-preferred" have the desired effect?
02-10-2023 10:44 PM
@bristolian It wont work if his firmware is incompatible hence why I asked in my first post.
@akc2 click on the green phone - then the three dots - then scroll down to WiFi calling. Or quick panel wifi calling.
02-10-2023 11:08 PM
Thanks I've got it working now!
Thanks for your help.
