on 02-10-2023 08:40 PM
hi there,hi there,I am currently working offshore I have full Wi-Fi connection to Starlink and I’m able to browse the Internet and make a WhatsApp calls without any issue. However, I am unable to make Wi-Fi calls or to receive any text messages. I have selected Wi-Fi calls on my iPhone 14, and the signal strength is good. is there a technical issue with my contract?
Solved! Go to Solution.
on 02-10-2023 09:19 PM
WiFi-calling is intended as a coverage-extension facility in the UK, an as mentioned - is not supported abroad.
If it were to function, then full roaming charges would apply.
on 02-10-2023 09:09 PM
Hi @Fishcake45
Welcome to the EE Community
WIFI calling isn't available while roaming.
David.
