Want roaming
Gorrgurefet12
How can i activate the roaming services
18 REPLIES 18
Are you already abroad or are you preparing to go abroad? Where? If abroad, do you have roaming problems?
I am currently in The Gambia and want roaming on my UK sim
James_B
EE Community Manager
Hi @Gorrgurefet12,
Please see EE Roaming - Help when abroad with your EE phone or device.
If you are still having issues after following those tips, please let us know.
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
am currently in the Gambia  and need to put my EE sim on roaming
can you activate the Roaming outside UK
Yes, you've already told us & I told you what to do.
@Gorrgurefet12 , you have not replied to the previous question asked or maybe not read what @XRaySpeX  has written, he has given you all the information you need to be able to roam and enable it, we cannot do this for you, it will also depend whether you have used your SIM card before going abroad, if pay monthly you can either enable this yourself as previously written or you would have to ring customer service as has already been suggested.
yes am on sim contract
