Voicemail pin
batesy201
Can't access voicemail, told i need to set up a pin. Instructed to press and hold 1, when i do i get looped back to the same message, i need to set up a pin etc. Tried calling 150, as soon as i press to connect it cuts off. Any ideas?
Batesy201
7 REPLIES 7
Katie_B
Hello @batesy201
Welcome to the EE Community.
Are you currently abroad?
Speak soon,
Katie 🙂
No I'm in UK, and i can use the phone for normal calls, I just can't seem to contact EE.
Hi @batesy201,
Thanks for getting back to us,
Is it a pay monthly account with EE you have?
What message do you hear when you dial 150 from your mobile phone?
Are you cable to connect using 07953966250 or 08000798586 from a landline number.
Alex 🙂
Hello
It wouldn't allow me to call 150, as i said, it was cutting me off as soon as i dialed the number. Not to worry though, I've managed to sort it out. Voicemail had somehow turned itself off, so i texted "vm on" to 150 and that worked.
Thanks anyway.
Hi @batesy201,
I'm glad you have resolved the issue now.
Have a lovely Christmas 🙂
Alex
I am abroad and need to set up voice mail and I have no pin and don’t know how to set up
James_B
Hi @Yaba1000,
Our Customer Care Team will be happy to help you setup a PIN if you get in touch.
