01-10-2022 11:41 AM
Hello there
I have no messages on voicemail but push the alert for me. It happened on Galaxy S20 first.
I put the sim to Iphone 14 pro and the red badge is permanently there.
THe VM OFF uneffective, because I can call the VM. It is a scam and we expect the EE fix it ASAP.
02-10-2022 08:50 AM
Hi @JackMack1
Try leaving a voicemail from another phone, listen to it fully, then delete it.
Restart your phone then hopefully, it's gone.
01-10-2022 12:03 PM
What do you mean by "push the alert for me"?
Try calling yourself from another phone, and leaving a voicemail. Then call your voicemail from your phone and delete the voicemail. Does your voicemail notification clear?
01-10-2022 07:20 PM
Exactly the same on my s22+ can't get through to ee for advice.
02-10-2022 08:50 AM
Hi @JackMack1
02-10-2022 02:08 PM
Thanks Chris
Your suggestion worked perfectly. Thank you so much !
JD..
02-10-2022 02:11 PM
07-11-2022 08:54 AM
Hello, I hope I can still piggy back on this message: I have two voicemail alerts, top left of my Samsung A53, next to the clock. Pull down the alerts, and two banners are there - phone services, new voicemail, recent time, EE. I have two SIMs in my phone, and this only appears for the EE SIM.
I have called my voicemail, and there it says there are no messages.
I am currently abroad, and for some reason cannot call the voicemail number to see if there are old messsages that need deleting.
I wonder if it is a phone issue, or an EE issue?
07-11-2022 09:01 AM
Hi, this solution does not work for me - I cannot switch off any voicemail alerts.
Even though I have called my voicemail, and I don't have any messages, I still have two alerts top left on my Samsung A53.
I'm wondering if this is a Samsung issue, or a EE issue?
07-11-2022 09:15 AM
