Unable to receive calls
Ali0721
I’ve had the same problem with my phone sometimes it diverts to 101 other times it rings out and then says number not available. I’ve checked the settings on my phone. I can’t see anything obvious and I’ve not changed anything.. this is extremely frustrating and confusing
Diverts are either "unconditional" (divert all calls) or "conditional", your phone will have menu options for each.
It sounds like you have a conditional "divert when unanswered" set to 101. With all other diverts - "when busy" or "when unreachable" set to voicemail.
suzymart
Isn’t it strange, I’m glad it’s not just me! I haven’t altered anything either and it was only when my mum called and went to leave a VM that it was discovered…..now feel like I need to randomly check all is well.
Sent from Yahoo Mail for iPad
Ali0721
I’ve had to turn my VM off . I’m not sure if this will resolve the issue. However my own prerecorded VM and settings for such disappeared ( I think after an update) and now I have this preset one . Any answers to why my VM gets diverted  to 101 or why it rings out and then says this phone is unavailable great appreciated !
Check my reply from 04/09 @ 3.31pm for some suggestions. Best to keep replies to the same thread by using the "reply" function - no need to start other posts querying the same problem.
