USA calls
pinkrobbiedog
Need help to be able to make and receive calls in the US. Tried locating a manual network. Doesn't work.
Can't make calls to phone EE>
upgraded to an data roaming etc packages - still doesn't work
Any ideas - am here for a week and can't use my phone, except for whatsapp
@pinkrobbiedog : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
If you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming billing add-on doesn't of itself activate roaming on your a/c.
Often just rebooting the phone is the simple remedy. Also try selecting a network manually rather than auto. Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
