Travelling to turkey
Kelly166
Hello, I’m travelling to Turkey on the 10th of October what are my options to use data?
1 ACCEPTED SOLUTION
You can view roaming costs for calls, texts & data using the following webpage - https://ee.co.uk/help/mobile/roaming/roaming-costs
Make sure you text ROAMING to 150 before leaving the UK, this ensures your phone is setup to use abroad. If you don't do this, you run the risk of not having coverage outside the UK.
The Travel Data Pass @ £7.84 per day for 500 MB. Text TRAVEL to 150.
Northerner
Hi @Kelly166
Buy a local sim if you are a heavy data user.
If you use the local wifi make sure you have a VPN active.
