on 07-10-2023 03:31 PM
I'm in America, and I have a roaming pass. But I can only text, not call. I have a basic 4g Nokia and there is a white triangle on the top left of the screen. I have a sim-only plan and don't use any data. EE says I can use my usual plan but I can't make calls, only send texts. Any help would be amazing!
on 07-10-2023 04:14 PM
Hi @Cmarti87
Thanks for coming here.
Are you able to try manually searching for a network in the phone settings to see if any show available for you to try and see if you can make calls?
Leanne 🙂
on 07-10-2023 05:22 PM
Yes! But I'm connected to EE and can send texts, just not make calls...
on 07-10-2023 09:06 PM
@Cmarti87 You can not be connected to EE in the USA. EE only has a network in the UK and isn’t a USA network. Have you tried restarting the device since you got there ? You should be connecting to AT&T or T-Mobile US.
on 08-10-2023 01:19 AM
What's the model of your basic 4G Nokia?
I suspect your issue could be lack of VoLTE - 4G calling - which is now a requirement in the US.
Does your phone have any options for enabling VoLTE or, failing that, disabling 4G and forcing 2G-only in the network options menu?
on 08-10-2023 04:48 AM
It's a Nokia 105 4G 2023. If I turn on 2G only, I get no service!
https://www.nokia.com/phones/en_int/nokia-105-4g?sku=1GF018TPA1H01
on 08-10-2023 08:38 AM
on 08-10-2023 10:52 AM
The Nokia 105 has VoLTE (4G-calling) support which is now essential in the US.
There may be an option in the phone's menus to enable VoLTE or check its status.
on 08-10-2023 03:19 PM
It says I'm on 4G and connected to T-Mobile... I can send and receive texts but not calls!
I rang EE tech support from my friend's phone but they couldn't fix it...
on 08-10-2023 03:20 PM
Yes, I'm connected to 4G T-Mobile. I can text but not call...
