on 27-05-2021 09:33 PM
Hello community,
I have recently got a new iPhone and have installed my SIM card everything is working. However someone has tried messaging me via SMS but the text is not being reciecved instead it is going to my old phone which has no SIM card and only WiFi connection, I use the old phone for browsing internet solely. I don’t understand what is going on and how this is possible? Both phones are connected to the WiFi but the phone without SIM card is receiving the text which should be received by the new phone as it has the SIM card, I am baffled as to what is going on and why is the text being intercepted by a sim less phone?
on 27-05-2021 11:07 PM
Did you move your existing SIM from your old phone to your new phone? Or were you sent a new SIM with the new phone? Was this done as an EE upgrade?
I have to say that it's impossible for a SIM-less phone to receive an SMS. It has no mobile no. & isn't even connected to the EE network. It can't be doing it by WiFi Calling over your WiFi connection for the same reason.
on 28-05-2021 12:09 AM
Hi @Dubz1 ,
Are the messages which you receive on your old phone inside a green box or a blue box?
Do they arrive even when WiFi is turned off on your old phone?
on 14-06-2023 11:25 AM
I can confirm this being an issue. I have the exact problem. moved sim from androind to iphone but some messages go to my old phone with no sim. I'm not sure if this will occur outside the wifi zone though. So XRaySpeX you're wrong. SMS can be received without sim.
A solution to this issue would be nice, thank you...
on 14-06-2023 11:46 AM
on
14-06-2023
11:50 AM
- last edited on
14-06-2023
01:19 PM
DanielPA
xxxx xxxxxx
[email protected]
on 14-06-2023 12:09 PM
Thanks again James...I have now turned off RCS chat. this should stop getting sms messages of the old phone.
here is a good aticle about this for anyone who needs it:
https://support.google.com/messages/answer/7189714?hl=en-GB
Thanks again James_B for pointing out the cause of this issue..
on 14-06-2023 12:32 PM
No problem @ilmane
Please follow the instructions in this Google support article to turn off RCS chat and that should resolve the issue.
