Roaming in the USA and Canada
KyleE123
Been in Canada the past few days and was working fine. But since mid day it's been patchy with giving me signal to anything with no R symbol appearing on my bars. Any help appreciated
134 REPLIES 134
Katie_B
Hi @RoamingCanada
I have sent you a private message.
Katie
Christopher_G
Hi and welcome to the community, @KatharineMay
I've sent you a private message, could you take a look and get back to me please?
Thank you.
Anyway you can help me out?
@Christopher_G
@Katie_B
efong
I have been in the US for 2 weeks now and network has been working perfectly fine with my free roaming pass. Suddenly it’s showing SOS only and nothing works unless I connect to WiFi.
Leanne_T
Hi @efong
Can you try and manually connect to a different network which shows available in your phone settings?
Does signal show if you manually connect?
Guest12
Same issue with an android phone. I set the roaming further with the customer service team. Switched on off several times. Looked for network manually. Nothing works.
Tried that and it connects for a minute but then goes straight back to SOS
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
@Delly82 : Same advice applies to you as I gave to OP.
GHawkes
Having  the same problem as everyone else from Florida
