30-03-2024 05:18 PM
Hey I have that exact issue I'm in the uae but I can receive or send texts especially verification messages.
I pay monthly is there a work around
30-03-2024 05:30 PM
Can you clarify what issue you have? Clarity on your symptoms would be useful.
Does your phone show a local network connection?
30-03-2024 05:53 PM - edited 30-03-2024 05:56 PM
@Tawfeek : You can send and receive texts but what can't you do there? Just what is the issue that you need help with?
30-03-2024 06:40 PM
Im currently in the UAE i am unable to receive TEXTS and Calls here, what is the solution for this as I need my code for verification .
30-03-2024 07:02 PM
As asked previously - does your phone show a local network connection? Your ability to get coverage abroad (which calls, texts & mobile data rely on) is dependent on roaming being activated - which allows your phone to connect to foreign networks.
If you now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 0798586 using a web-calling app such as Skype over WiFi.
