18-02-2026 06:06 PM
I am in Dubai and wish to add in a 24 hour roaming pass for tomorrow. I am an EE customer on a monthly contract. I didn't let EE know that I was travelling to Dubai and didn't receive a text from them on landing at the airport. I can't connect to a local network and I can't seem to purchase the add on from either EE's website or using my EE app. What should I do to get connected?
18-02-2026 06:13 PM - edited 18-02-2026 06:35 PM
If not.....on pay-monthly, this needs to be enabled manually - usually by texting ROAMING to 150 before leaving the UK. Did you do this?
If you are on pay-monthly and now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 9566000 using a web-calling app over WiFi.
