Re: Unable to connect to network abroad despite Roam Abroad Pass
Naga_v
I traveled abroad (USA) on 26.07.2024  after checking with customer support  and waited 1 and half day. There is no sign of  network detection. only appear SOS. can't make any calls.  Very bad experience, lost hope and feel helpless .
Katie_J
Hi @Naga_v.
Thanks for coming here.
Before leaving the UK did you text ROAMING to 150 to activate roaming on your account?
When you landed in the states did you receive a welcome text?
Katie
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
