Roaming in thailand
Crilly1
I have the roaming row add on in my pay monthly contract but I can’t connect to a network.
@Crilly1  What add ons you have doesn’t mean roaming is enabled its just an add on,  you enable roaming by testing ROAMING to 150 before you leave the UK.    But have you tried restarting the device since you got there ?  Have you tried a manual network search ? If nether of these work you can use live chat via the EE app under help to chat with customer support to request roaming be enabled on the account
If you are on pay-monthly and now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 9566000 using a web-calling app over WiFi.
Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before leaving to go abroad?
If you are on contract, did you activate roaming on your EE a/c before leaving UK by texting ROAMING to 150? Having a roaming billing add-on doesn't of itself activate roaming on your a/c. Having roaming activated on your EE a/c, not just on your device, is crucial to using your contract SIM abroad.
Otherwise if you are on contract you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. using a web-calling app over WiFi.
