Re: Please help - Mobile phone showing as sos only
Sarahx10
Hi
I landed this afternoon in the US, I have the de smart sim plan with the roam abroad pass activated. And I have the same issue, I can’t connect to any network manually or automatically…
Please help.
I have contacted the live chat but no one is there at the moment.
7 REPLIES 7
Christopher_G
Is roaming and international calling activated in your My EE account, @Sarahx10?
It's under Account Settings > Parental & Data Controls.
Yes I was in Europe just ten days ago, it was working
Christopher_G
OK, thanks @Sarahx10
What happens when you try to search for a network? Does it show any networks at all? Are you in an area where you know there's mobile signal?
There are 8 different networks and yes my friend has signal on her iPhone.
Adding a billing add-on doesn't enable the roaming facility which allows your phone to connect to local networks in foreign countries.
On the basis that you're on pay-monthly, you can activate this by logging into your myEE online account or app, navigating to "parental & data controls", and making sure "international roaming" & "Call abroad & premium rate" are both enabled.
There is no option to enable international roaming or calling abroad.
i still need help cuz it stopped connecting to networks again..
Christopher_G
I recommend speaking to the live chat team again, @Sarahx10.
Hopefully they can help get you connected again.
