27-06-2024 09:18 AM
My roaming is not working
27-06-2024 09:23 AM
In what way is your roaming not working? Has it worked before?
27-06-2024 12:38 PM - edited 27-06-2024 12:38 PM
@Mandy2021 : Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before you left to go abroad?
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
