Sos
Mon7392
SOS on my phone and won’t let me make a call when traveling
Does your phone show network coverage? Are you travelling in the UK or abroad?
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
