Re: EE roaming pass hardly worked in usa
Kerr616
Hi, just had the exact same problem in Las Vegas, also went to San Francisco but unsure if had signal there as didn’t need to make any calls.
we had a medical emergency in Las Vegas and mobile signal that at best was one bar
Regardless of any billing add-on, your ability to get coverage abroad (which calls, texts & mobile data rely on) is dependent on roaming being activated - which allows your phone to connect to foreign networks. "One bar" is still a bar.
If you are on pay-monthly and now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 0798586 using a web-calling app such as Skype over WiFi.
@Kerr616  So by your own admission the signal was there and was shown on the device.   EE can not do anything about the network service you got in LV but did you try a manual network search?
