Phone is not making calls not even 150
Sw442
I’m trying to make calls and my phone is just disconnecting even to 150 - what can I do?
10 REPLIES 10
@Sw442 : Are you on contract or PAYG?
Contract and I can make calls through watsapp - I don’t make many calls which it why it’s surprised me
Does your phone show network coverage? Are you in the UK or abroad? When were you last able to make calls? Can you send & receive texts? Can you use mobile data?
I can message, coverage is good and the network tested it. And a couple of days ago
James_B
EE Community Manager
Are you in the UK or roaming, @Sw442?
I am in the uk
Katie_J
Hi @Sw442.
Thanks for confirming.
Does this happen in multiple locations?
Are you able to try your SIM in another device?
Speak soon,
Katie
It happens everywhere I am not able to try that no.
the strange thing is on watsapp and other apps it’s fine
Katie_J
Hi @Sw442.
WhatsApp will be using your mobile data or WiFi if you are connect to that.
I would recommend trying a replacement SIM to see if this issue continues.
Katie
