Re: EE roaming in turkey
LucyS1
Hi I’m in turkey at moment as my EE doesn’t working at all, no service or can’t even contact to anyone
Katie_J
Hi @LucyS1.
Thanks for coming to the EE community.
Did you activate roaming before leaving the UK?
When you arrived in Turkey did you receive a welcome text?
Speak soon,
Katie
If you are on pay-monthly and now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 0798586 using a web-calling app such as Skype over WiFi.
